Accenture
Last activity: 24 May 2020 5:20 EDT
Unable to Start Process iexplore.exe - Start process injected failed
I am getting the following error when I click on start interrogation after adding a web application -
Unable to start process iexplore.exe - Start process injected failed
Hello!
Thank you for posting your query on PSC. I came across this discussion which may have some great pointers for you. Please read through the replies and let us know if any of the suggestions worked for you?
Error: The process iexplore.exe failed to start within the given time frame.?Continue waiting.
Accenture
Its still not working for me !
Shivanshu Kapoor
You will need to open a SR.
Hello!
Please let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Thank you,
Binghamton University State University of New York
is there any solution to the question in this thread?
Fifth Third Bank
change the following setting and try:
Tools -> Options -> Pega Robotics -> Studio Diagnostics -> Output Publisher -> Off
Yep, it worked thanks a lot. It would be even great if you could throw some light on why this had to be done. TIA
Fifth Third Bank
Sorry for late reply. We spent more than a month to resolve this issue and we had a WebEx with Pega Support team also but didn't worked.
Finally we started trail and error and figured after changing this setting it was working. We didn't get any idea why this setting causing this issue.
Mphasis
I looked this configuration it's already off. Any other idea?
I have attached the screenshot of the error i am getting for more reference.
1.png : When I tried to interrogate
2.png When i tried to start the automation
Infosys
For me, changing the BrowserBitness (from Properties) to Default fixed the "Unable to start process iexplore.exe" issue.
Ernst & Young LLP
Hi iRAMARAM,
Your given solution is skipping one issue of "Unable to start process iexplore.exe". Now the problem is after opening web application say www.google.com the interrogation form is behaving like Windows interrogator as it contains only 3 interrogation methods and doesn't include the Select Element and HTML Table Designer. More over the bulls eye is not binding with the targets to create controls, instead it is creating one control over whole webpage.
Kindly look into this and suggest the solution if someone really done with it.
Thanks & Regards,
Mohd sirajuddin
Accenture
This solution worked for me, thank you!
RPA
I tried -- Tools --> options --> Pega robotics --> Studio diagostics --> Output publisher --> off
Still facing this issue.
Accenture
This comment/reply has been branched into a new post
Accenture
I am also facing this issue even after changing the output publisher setting to "off"
Accenture
In addition to changing the output publisher setting to off, another poster commented to change the browser bitness to default instead of 32 bit. This resolved my issue.
