PEGA Personal Edition 8.1 Startup issue
Hi everyone,
I have successfully installed PEGA personal edition 8.1 but encountering "Can't reach this page" issue while start up, I am trying to use this within our company firewalls, Please see attached screen shots and below error messages
Message in the login page launch:
Hi everyone,
- Make sure the web address http://localhost:8080 is correct
- Search for this site on Bing
- Refresh the page
- Check that all network cables are plugged in.
- Verify that airplane mode is turned off.
- Make sure your wireless switch is turned on.
- See if you can connect to mobile broadband.
- Restart your router.
More information <id id="moreInformation">More information</id> |
There was a temporary DNS error. Try refreshing the page.
Error Code: INET_E_RESOURCE_NOT_FOUND
Message in the server startup command prompt
pg_ctl: another server might be running; trying to start server anyway
waiting for server to start........ done
server started
Using CATALINA_BASE: "C:\PRPCPersonalEdition\scripts\..\tomcat"
Using CATALINA_HOME: "C:\PRPCPersonalEdition\scripts\..\tomcat"
Using CATALINA_TMPDIR: "C:\PRPCPersonalEdition\scripts\..\tomcat\temp"
Using JRE_HOME: "C:\PRPCPersonalEdition\jre1.8.0_121"
Using CLASSPATH: "C:\PRPCPersonalEdition\scripts\..\tomcat\bin\bootstrap.jar;C:\PRPCPersonalEdition\scripts\..\tomcat\bin\tomcat-juli.jar"
Picked up _JAVA_OPTIONS: -Xmx512M
Error occurred during initialization of VM
Initial heap size set to a larger value than the maximum heap size
Please help to resolve this issue
