PricewaterhouseCoopers LLP
Last activity: 21 Mar 2019 11:21 EDT
Pega RPA quick question
I am starting off pega RPA with no background. I have completed some trainings online and got started.
I have a HTML table which I have interrogated using a HTML table control.I need to get this small table in Excel. I have defined the match cells and data cells and table section (don't really know what table section is ) but based on what I saw on the internet, for the get table / get data to work using excel connector , you need to define the table section. I am stuck and not sure how to proceed here. How to give the table as an input to the Excel connector. I want to do this in an outer loop. based on what I click on a different page, it will be a different table but with same structure. A separate excel is to be prepared for each table. The table itself is very simple. it has about 10+ columns and only one row.
Can you please help? If there is a video I can watch and understand the import table method with HTML table I should be good.
Ashish
