Deloitte SA
Last activity: 16 May 2017 10:03 EDT
Important Questions Set 1: Quick Setup on Pega UI Screens
I am very new to the Pega Environment. I am a UX Professional and started building screens using Pega UI. I am having the below small questions, that all you professional can reply me accordingly.
Q1: Where is my Master CSS File? Where can i find it immediately for the updates?
Q2: Is it possible to import my existing CSS3 code in the Pega?
Q3: Is it possible to import my HTML code in Pega?
Q4: Is it possible to create dummy data table without using any external sources?
Q5: How to connect CSV file as Data Source?
Q6: How to create Editable Fields for the Data Table?
Later some more questions coming soon.
HI Raghavendra,
1.I am not exactly sure but as per my knowledge when we define styles in skin,css is automatically generated.
2.Create a text file with file type extension as css and add your code(TECHINCAL-->TEXT FILE)
3.Create HTML/HTML FRAGMENT as per your requirement(Technical-->HTML/HTML Fragement)
4.You can create the same from data explorer
