Virtusa Consulting Services
Last activity: 12 Mar 2019 4:47 EDT
Pega 7.4.0 installation failing
Hello Team,
I have downloaded setup Pega 7.4.0 from PDN and then trying to install it. But facing below issue while running `install.bat` file.
BUILD FAILED
H:\Pega\Pega 7.4\scripts\setupDatabase.xml:471: The following error occurred whi
le executing this line:
H:\Pega\Pega 7.4\scripts\setupDatabase.xml:959: Set a password for the administr
[email protected] operator by using the pega.admin.password property. The password m
ust start and end with non-whitespace characters, be between 5 and 64 characters
long, and cannot contain an *, ?, [, or ].
Total time: 1 second
Exiting with Error
And also In the extracted folder I noticed that the setup of JDK is missing. PFA screenshot.
Abhishek
Hi Abhishek,
Have you updated setupDatabase.properties with the required database connection properties?
Regards
Simon
Hi Abhishek,
While installing Pega7.4 modifying setupdatabase.properties is not required unless you want to generate the DDL manually.
Could you please let us know the detailed steps that you have followed while installing Pega 7.4.
Vikash
Hi Vikash,
Thanks for your comment.
Please find below steps which i have followed :
1. Downloaded Pega 7.4 version from PDN website.
2. Extracted the rar file, PFA for the same.
3. Tried to run scripts\install.bat file through command prompt. I got below error,
H:\Pega\Pega 7.4\scripts>install.bat
The JAVA_HOME environment variable must point to a
valid installation of the JDK.
Exiting with Error
4. When i have googled it then i came to know that the JDK setup is missing inside Pega 7.4 setup.
5. Then I externally copied the JDK 1.8 in the Pega 7.4 setup.
6. Tried again to run the scripts\install.bat file, then i got below error,
Invoke our ant script, passing in the arguments as collected
Buildfile: H:\Pega\Pega 7.4\scripts\setupDatabase.xml
install:
Hi Vikash,
Exiting with Error
install:
Initialization:
[echo] Performing Install Finalization
[echo] Using logging configuration from: ./config/deploylogging.properties
[delete] Deleting directory H:\Pega\Pega 7.4\scripts\taskRuntimes
[mkdir] Created dir: H:\Pega\Pega 7.4\scripts\taskRuntimes
[pega:propertyparser] Reading Properties from: H:\Pega\Pega 7.4\scripts/setupDat
abase.properties
[pega:propertyparser] pega.jdbc.driver.jar=
[pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
[pega:propertyparser] pega.database.type=oracledate
[pega:propertyparser] pega.jdbc.url=jdbc:oracle:thin:@localhost:1521/orcl
[pega:propertyparser] pega.jdbc.username=pega
[pega:propertyparser] pega.jdbc.password=*****
[pega:propertyparser] pega.admin.password=*****
[pega:propertyparser] rules.schema.name=
[pega:propertyparser] data.schema.name=
[pega:propertyparser] customerdata.schema.name=
[pega:propertyparser] user.temp.dir=
[pega:propertyparser] pega.zos.properties=
[pega:propertyparser] system.name=pega
[pega:propertyparser] production.level=2
[pega:propertyparser] multitenant.system=false
[pega:propertyparser] update.existing.applications=false
[pega:propertyparser] update.applications.schema=false
[pega:propertyparser] automatic.resume=true
[echo] *** JVM Arguments -XX:MaxHeapSize=1280m ***
[pega:hasenoughspace] Found 23371816KB of free space on 'C:\Users\ABHISH~1.ABH\A
ppData\Local\Temp\'
BUILD FAILED
Exiting with Error
Abhishek
PEG
I'm reasonably sure you will need to configure the setupDatabase.properties file if you're intending to install the system using the install.bat script.
Conversely, if you'd rather go through the UI lead installation, you can run: -
java -jar PRPC_Setup.jar
This approach won't require the setupDatabase.properties file to be configured beforehand.
I missed to add in my previous comment that setupdatabase.properties should not be modified when installing using GUI as all the values are passed to using the GUI.
Also when you are using setupdatabase.properties, there is a field "pega.admin.password" in line 48 where you need to provide a password for your administrator operator.
It is clearly mentioned in the guide that if you do not set this password the installation fails.
Please provide the password and then try installing.
Is Java installed in your system.Please verify java version and set java home environment variable.
Abhinav
