Tech Mahindra
Last activity: 19 Feb 2019 1:11 EST
Select multiple buttons in same layout
Here i want select multiple buttons in same line please give the suggestion for this how to set the functionality in skin.Please check below attachment.
Thanks in advance.
FR
Looks like you should be working with Checkboxes really. Or you can try creating checkboxes that looks like button.
Tech Mahindra
Thakns Marc,
Here Provider is one type and provider contain 4 types(at&t,sprint,t-mobile, verzion) how we taken it and these are saved into database in provider type only.
Thanks in advance
CollabPartnerz
Below post might help you.
https://collaborate.pega.com/question/multiple-select-allowed-repeating-dynamic-layout
Hi ,
Somewhat similar Ui can be achieved using checkboxes and for these checkboxes use some styles.
Please find a sample here :
Tech Mahindra
Thank u sahuv,
Here i click checkbox it how to save in db . Here use this HTML code for checkbox shape then how to saved(true/false) conditions in database.
Thanks.
Use the Html form the pega (OOTB) for checkboxes and just use the CSS to customise the UI.
Which will ensure that it will get posted on submit/section refresh/postdata.
These buttons contain the checkboxes. Now if you want to manually set this, you can use a Data Transform. In this DataTransform iterate through the page and set the value "pySelected=true". Once it is true these checkboxes(button), will be marked as checked. Then after that, we need to do a RefreshThisSection.
So basically, we have to perform 2 steps.
1) Run Data Transform
2) Refresh This Section.
