OneAmerica
Last activity: 14 Oct 2019 4:59 EDT
Connect-FTP 'Local file' cannot be found/read
We are attempting to use Connect-FTP and receiving following error:
"File does not exist or cannot be read: /usr/local/tomcat/temp/StaticContent/global/ServiceExport/test.txt"
We are receiving same error when attempting to use both relative and absolute path in 'Local file' parameter of the Connect-FTP method. I cannot find any other threads with solutions to this problem. The file is definitely available, I have tested running @baseclass.DownloadFile using exact same path in both relative/absolute scenarios and the activity works.
Our requirement is to send file located on our SFTP Cloud server to internal FTP Server and we received the same error, so using a file on temporary path was the next attempt to rule out SFTP repository issues and even then it was unsuccessful as I mentioned above.
Thoughts?
