  RT
Last activity: 17 Jul 2019 1:40 EDT
Icon classes are not visible after upgrade from 7.1.7 to 7.4
We have used py-icons classes to add icons to our application which worked before upgrade to 7.4.
Now none of the icons are visible. Used icon classes in links and noticed that in 7.4 link caption is required. Even after adding captions icons are not visible.
  Areteans
Hi Rachinda,
Could you check if py-icon css exists in skin rule under Included Styles Tab "Additional Stylesheet" category.
If not, please add and verify.
Bala
  RT
It's already there.
Are you using OOTB skin.. pyEndUser? If not can you try once and let us know.
  RT
We are not using the OOTB skin, We have a custom one. Tried adding pyEndUser as the inherited skin of our custom skin and still no result.
Also tried using pyEndUser skin as the application skin and icon classes are still not visible.
  Areteans
I think this is something that requires debugging in application. Please raise a Support request for this issue.
  RT
Found the cause of this issue and now resolved. Didn't raise a SR.
Hi @Rachinda ,
Glad to know the issue is fixed. Please feel free to share the resolution om the community for the benefit of users who might come across the same query.
Thanks!
  Nationwide Building Society
Hi Rachinda,
Could you kindly share your solution.
  RT
Please try pointing the Application UI Kit version to the latest one.
