JP
Last activity: 15 Jan 2019 10:56 EST
Is Marker file "deprecated"?
I have always deleted "PegaRULES_Extract_Marker.txt" every time we import R-A-P / Hotfix to fresh out cache. However someone has found below article in Pega Help - "This file is deprecated. Use System Management Application (SMA) instead."
Can someone let me know what exactly that means? Marker file does exist in 7x and 8.1. SMA is deprecated in 8.1. I know SMA has cache deletion capabilities but there are too many buttons and people feel it cumbersome with SMA approach. I only use SMA when I do not have access to file system in very limited situation. Does marker file deletion and SMA deletion make any difference?
You shouldn't need to delete the extract marker file after performing an import. If that is necessary, it suggests there is a bug that should be looked into.
