![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689875000/a882edd7-51c6-43e7-9e07-b264fa3e57e8.jpg?itok=16Ob5agW)
Swift
Swift
BE
Swift
Posted: Oct 23, 2018
Last activity: Oct 25, 2018
Last activity: 25 Oct 2018 9:42 EDT
HTTP 403 Error in REST and SOAP connectors
When trying to create and test any connector rule, say Connect-SOAP or Connect-REST, a HTTP 403 error comes up.
Show More
pyStatusVal - Fail: Unexpected HTTP 403 Response code
pyStatusMsg - the HTTP response code of 403 indicated a client error. The response data may contain a reason.
We get the same error when we try to run OOTB Pega API REST services using connect-REST.
Strangely these services run and work standalone as well as when invoked from SOAP UI.
Even using the Connect-SOAP wizard, in the very first step of configuring the WSDL source, this fails with same HTTP 403 error.
Same is the case for Connect-REST wizard when testing connectivity.
On further investigation, we could see the following information on the error :
Code:
403
The response data was not recognized as JSON or XML and cannot be saved.
Response Data : ![](/sites/default/files/collaboration/inline-images/error_0_0.JPG)
Seeing a similar response no matter what the type of Connector it is.
Kindly help in resolving this issue.
Pega Platform 7.3.1
Server : JBoss
Show Less
