Capgemini
Capgemini
SE
Capgemini
Posted: Sep 10, 2018
Last activity: Sep 11, 2018
Last activity: 11 Sep 2018 8:14 EDT
Creating File System repository with network drive
I'm creating a File System Respository for devOps. Since, one of the network drives is acessible from orchestration and all candidate systems, I tried creating File Respository there by providing the resource path as \\XXX706\common But is not allowing me to save the repository rule. However, when I use any folder from D drive, it saves and connect successfully. I'm getting the following error in logs:- com.pega.platform.integrationengine.repository.RepositoryException: There was an issue during checking if a file or directory exists. at com.pega.platform.integrationengine.repository.internal.RepositoryManagerImpl.getFileReference(RepositoryManagerImpl.java:581) ~[integration-engine.jar:?] at com.pega.platform.integrationengine.repository.internal.RepositoryManagerImpl.exists(RepositoryManagerImpl.java:443) ~[integration-engine.jar:?] at com.pegarules.generated.activity.ra_action_validate_883518784956e9adaf184698a927437a$Pz_8_0_1.step(ra_action_validate_883518784956e9adaf184698a927437a.java:800) ~[?:?]
Could you please help me how to use network drive as repository?
Thanks all for the comments..
I got the issue. The application server was running with a different user for which access to the shared drive was not granted. I started it with my id, then I was able to connect the shared drive.
