LDAP2 Authintication Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation.
I am trying to login using LDAP2 and getting below error. WC:01.01] (.authentication.SchemePRCustom) ERROR carepath-uat.wellcare.com|xx.xx.xx - Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation. The most likely cause for this is that your Data-Admin-AuthService record attempts to map directory attributes to PROPERTIES THAT DO NOT BELONG TO DATA-ADMIN-OPERATOR-ID class. Check your D-A-AuthService record for bad entries or typos. When i change the default access group in my Operator-ID profile, i can access but only one access group is creating the problem. That access group is associated with my AD group. rest access groups not creating any problem.
The most possible cause of this is when the unauthenticated access group in browser requestor doesn't have access to properties mentioned in the authentication service mapping tab.
Check this article:
https://collaborate.pega.com/discussion/not-able-set-properties-during-authentication-prcustom-authentication
