Bluerose Technologies Pvt Ltd
Last activity: 10 Jul 2019 2:30 EDT
I am trying to open work class assignment in portal. I am able to open the workitem in portal as review mode instead of editable
Even i am facing the same issue. i am trying to open work class assignment in portal. So I have created work class Repeating grid(Work class Report Definition) in section and i am able to open the workitem in portal as review mode instead of editable. I have also tried using join in RD like [Assign-Worklist (.pxRefObjKey) equals WorkClass(.pzInskey)] in Data access tab. In Action tab of repeating grid i am passing .pzInskey in Open-Assignment Action event. But i am receiving below error. can you please share some thought on this.
I have also tried alternative approach like by setting .pyAssignmentKey = {.pxPages(Assign).pzInskey} and passed this assginmnet key for open assignmnet action but it throws "Empty Assignment Key" error.
Error:
Object key Read/write true
Harness class Frame name
Error message Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'OPENANDLOCKWORK' that applies to 'Work Class name'. There were 6 rules with this name in the rulebase, but none matched this request. The 6 rules named 'OPENANDLOCKWORK' defined in the rulebase are: 6 unrelated to applies-to class 'Work Class name', for example: 'Assign-'.
i have used below link's as reference:
Error:
https://community.pega.com/support/support-articles/unable-open-assignment-grid
