Vodafone Shared Services India
Last activity: 15 Nov 2018 10:48 EST
One of the node doesn't response after login
In cluster, on one of the node, when logged in, designer studio gets opened.
then one pop up comes with 3-4 errors and nothing works on developer portal.
Errors present in catalina are:
1. ngineinterface.service.HttpAPI) ERRORError adopting XML from post data. com.pega.pegarules.pub.clipboard.InvalidStreamError: InvalidStream com.pega.pegarules.data.internal.clipboard.XMLStream.newStream(String, StorageStream) sax parse error: Content is not allowed in prolog.
2. Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'PZUPDATEREQUESTORBROWSERDETAILS' that applies to '@baseclass'. There were 1 rules with this name in the rulebase, but none matched this request. The 1 rules named 'PZUPDATEREQUESTORBROWSERDETAILS' defined in the rulebase are:
1 related to applies-to class '@baseclass', but were defined on subclasses: 'Code-Pega-Requestor'.
