Tenet Healthcare
Last activity: 21 Oct 2019 5:04 EDT
How to import Pega Robot OCR Essentials Application exe into Robotic Studio
Hi
I am using Robotic Studio 8.0.1096, i am not able to add/import Pega Robot OCR Essentials Application exe into Robotic Studio. Any suggestion is much appreciated.
Also I registered with Abbyy , got application name and password , how to invoke processImage method for image processing in Robotic Studio?
***Moderator Edit: Vidyaranjan | Updated Platform Capability***
After installing Robotics Studio:
When you request a new version of Robotics there should be .ZIP called "Pega_Robot_OCR_Essentials_8.0.0.ZIP" unzip that and there should be three files inside there. Place all these files in the same folder and run the .EXE. This should install the Pega Robotics OCR.
You should then see methods such as "Click By OCR" for non-web controls.
Documentation on OCR can be found here: https://community.pega.com/system/files/pdfs/Creating%20automations%20using%20the%20Screen%20OCR%20feature.pdf
Chris
If anyone gets error launching the article provided by Chris, refer the following link-
Thanks!
EPAM Canada
I see this link is not accessible, says not authorized
can you help , emailing the pdf
Please refer the attached file.
Thanks!
Also, updated link: https://community.pega.com/knowledgebase/documents/creating-automations-using-screen-ocr-feature
Ford Motor Company
Is there any application on which I can try out the Pega OCR functionalities to learn how exactly this capability of Pega works.
Thanks.
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
Cognizant Information technology
Hi
Is there is way to install Pega OCR Component in Window 10?
Could anyone please help on this.
Regards.
