UST
Last activity: 22 Jun 2018 4:23 EDT
What is the exact use of EDIT view in Pega 7?
Name |
Label at run time |
Name |
Label at run time |
Purpose |
Create |
[None] |
Prompts a user to provide information about a case, prior to processing the first step in the case life cycle. |
Edit |
Edit details |
Allows a user to modify case information at run time, when the Edit button or Actions > Edit Details menu is clicked. |
Review |
Case information |
Presents case information to a user in a read-only format.
Hope it helps. |
I guess you can check below link for details on views
https://community.pega.com/knowledgebase/articles/editing-view
https://community.pega.com/knowledgebase/articles/views-case-type
Thank You
UST
Name |
Label at run time |
Name |
Label at run time |
Purpose |
Create |
[None] |
Edit |
Edit details |
Review |
Case information |
Hope it helps. |
UST
Will Cho
Once you complete the flow you would be able to see the options
UST
UST
Cheers :)
Shraddha poojary Fahad Khan
