CYBG
Last activity: 21 Feb 2019 14:17 EST
What exactly is "@java"?
In our custom Authentication activity we have a Property-Set step that uses "@java". It causes the following warning:
"The usage of @java in expressions is deprecated and support for it will be removed in a future version. Consider replacing @java with utility functions or other product features."
However, the reason for this being present is that it ships with PRPC OOTB. Please can someone explain:
1) What this does and how it differs from using a java method?
2) Why does PRPC ship with example code for you to copy that contains guardrail breaches?
Many thanks for your help,
Mike.
