Virtusa Consulting Services Pvt. Ltd.
Last activity: 11 Feb 2016 5:22 EST
What is the exact use and behavior of a multi process step under a stage?
When we add a step to a stage we can select step type as Single step assignment, Multi step process etc. I understand that single step assignment means a flow with a single assignment and multi-step process means a flow with multiple assignments and the process will come out of that step only after passing through all assignments defined in the flow.
Please correct me if I am wrong. If I am correct, is there any use of multi-step process other than this?
Goutham
