Controlling run order for multiple control links
It seems that in Robotics Studio, it is possible to have multiple control links emanating from a single control (see attached image).
Our own testing seems to indicate that the links run in sequence, not in parallel. Assuming this is true,
is there any way to
1. control the order in which the links are executed and
2. in some way display the order on the GUI interface or, if not
3. disable the creation of multiple control links on the output side (in the same way multiple data links on the input side is disabled)?
