Pega
Last activity: 30 May 2018 12:04 EDT
BIX extract to folder
I am using BIX to extract case data in XML format to a folder specified in file specification tab, when clicked for test connectivity it fails displays below message
com.pega.pegarules.pub.PRRuntimeException: Path: /XXX/XXX mentioned in the output directory is invalid
The above code is working in Dev but fails in QA environment, what would be the access/ user from PRPC for which access to be requested for writing into that above Path.
Thanks in Advance.
