Unable to view monitoring nodes in PCM Server
Unable to view monitoring nodes in PCMServer. i have enabled PCM client while subscribing the application.
Please suggest.
Nikhil
Please suggest.
Nikhil
Hi Nikhil,
Please review the replies in the below post and let us know if it helps you!
Hi Lochana,
I have installed PCM server in one server and PCM client in other server and i have enabled DSS as required and subscribed the applications as well.
But iam unable to view the PCM client node under view monitoring nodes/clients tab in PCM server.
nikhil
Quick questions for clarity.
1.) Did you "Subscribe to a New PCM Server" when subscribing on the client?
2.) Have you created new governance policies?
Provide a screenshot of the PCM Client Portal on the client server?
