NCS Group
SG
Last activity: 9 May 2018 1:01 EDT
Show warning message to user without preventing them from submission
I had a Validation Rule, and set the Message to Warning>Informative>Functionality
But in clipboard the message is still labeled as "error". The user still cannot submit their case.
Hi There,
I am able to create the same issue in-house. I will check this internally and will update you accordingly.
Rachit
NCS Group
SG
Thanks bro, any updates?
NCS Group
SG
Anyone?
As per the discussion I had with Engineering team on this, there is no provision to add to Separate warning/error on the property in the rule. It will always show an error, when considered on UI.
Thus it seems to be expected.
NCS Group
SG
Thanks for clarification. Then how should we implement warning feature properly?
Water NSW
Hi Sen,
As i understand, you have to display messages to the user but i should not stop user to proceed.
How about using Visible when conditions for your messages ? Will that help instead of using validate rules (which will actually add error message to your pages). If there are more number of properties in the form, probably you can display all the messages in one subsection (near to submit button/top of the case where messages will be visible to user).
NCS Group
SG
Thanks for suggestion, but we don't want to have too many customizations.
Swedbank AB
SE
I agree with Sundeep. You can place warning messages in layout/section with possible visible when conditions in top your section and onchange of every feild apply refresh section.So user will know as soon as they enter data. In this no customizations required you just need to place visible conditions. You can also verify 7.2 CLM had option like on submission of approve button in perform harness they will show confirmation popup. You can try that option as well.
Deva
