How do I log a warning message from a data transform
in a data transform when using pxLogMessage you can specify a log level, i,f, w, e etc
but to be able to make use of the log level - how do i set the log level for the logger of data transform
In activities you view java code and see the logger name but there is no logger name when viewing java for a data transform - so how can you change the log level for your data transform -what is the logger name for a data transform??
