Tech Mahindra Limited
Last activity: 7 Apr 2018 2:33 EDT
Placeholder for Dropdown Control Issue
I have a dropdown with values, included placeholder as "Select". Issue is : placeholder is getting in the dropdown along with the Tablelist values..
pls help how to remove from the dropdown and use placeholder...
Can you perhaps rephrase your question and/or provide screenshots?
It sounds like you want to include the "Select.." placeholder that is often seen in dropdowns. You've included this, and see it at runtime.
But then at the end of your post you are asking how to remove it?
My Requirement is have to put placeholder but it should not be visible again in the dropdown list values.
Hello Nag,
What is the source of the Dropdown ?
Are you using a Local list for dropdown source? [Local List may be having Select as an entry]
Could you please provide some snapshot of the configuration.
Regards
Sibani Saidarsini
I'm using local list values, please find below attached screen shot.
Sayak Bhattacharjee Egemen Celik Nirant Chikate SHIVAM ANAND Guangri Liang and 1 More
Hi ,
I think you have attached the runttime screenshot. please attach snapshot of the configuration @ design time.
Hi Nag,
You need to attach the snapshot of the property configuration which you have you have used as dropdown source.
Regards
Sibani Saidarsini
Hi Nag,
Regards
Sibani Saidarsini
J.P. Morgan Services India PVT Ltd
in the below image place_holder is a placeholder shown after clicking the "includeplaceholder" check in the drop down, i guess you are expecting that
this place_holder should not be shown in the drop down list but may be to be show as a heading.
pls let me know?
Hi
Yes, Placeholder should not be shown in the dropdown list.
Aruna Babu G SWETHA ABIRAMI M
