ESSIT
Last activity: 18 Sep 2018 6:02 EDT
How to add attachment in case
How to add attachment in case.
***Updated by moderator: Lochan to branch reply and create new post***
Hi Lakshmi,
You can use AttachContent smart shape in your flow to add the attachment into your work object. Sample example can be found in the attachment.
Regards
Mahesh
Hi Lakshmi,
You can also use Attach Content control in a section for the same.
SHREAYA S Siva Sowndarya Medam
Kindly check below discussion also. It may help you.
https://collaborate.pega.com/question/how-automatically-attach-file-work-object
Accenture
SG
Hi Everyone,
So i have a similar requirement. I have a WO which has something called issues. So each WO can have multiple issues and issue itself is not a WO but just a page with a unique ID of its own. So each issue can have multiple attachments and user has the privilege to either upload new attachments to a particular Issue or download existing attachment from an issue. The problem is that as Issue is not Wo so the Attachments will be linked to the WO by Pega norms and it will be difficult to know which attachment is for whoich issue or which one to download. Can anyone plz help in this. So that attachments can be linked to a particular issue and can be downloaded as well.
Updated: 18 Sep 2018 6:02 EDT
Hello!
This query is now taken forward through a new post: Query related to attachments
It has also garnered replies! Please review and respond over the new post.
Thank you,
CollabPartnerz
