Does Pega is using temp folder(CMIS_Documents) when uploading a file from Pega
We need to use CMIS attachments and attachments getting stored in CMIS_Documents temp folder
Does Pega is using local file system when uploading a file? So, does Pega uses some sort of temp directory in the middle on Pega server?
Does this applies also to normal case attachments?
How these temp files will be deleted automatically from CMIS_Documents if we are storing files automatically in in temp folder?
