Does Pega is using local file system when uploading a file?Some sort of temp directory in the middle on Pega server?
We need to use CMIS attachments and I got the following question from the client.
Does Pega is using local file system when uploading a file? So, does Pega uses some sort of temp directory in the middle on Pega server?
Does this applies also to normal case attachments?
Dmitrii
