How to delete downloaded file in pega server temp folder
Good day!
Pega front-end is saving the file in filenet using CMIS service, then after saving it in filenet, the user can download the files saved in filenet.
The design on how pega retrieves the file from filenet is, pega will send a request using CMIS service to filenet then filenet's response is, will send the file then pega will save the downloaded file in pega server temp folder and the file can now retrieve and save in user's pc memory (user who initiated the download).
The dilemma is how we can delete the downloaded file stored in pega server temp folder?
Is there any OOTB rule can we use to achieve this?
Thank you in advance and more power!
Feli
Hello Feli,
Could you tell me your requirement for deleting this downloaded file on the Pega server temp folder?
If you have disk space usage issues then you should rely on SystemCleaner. .
You can check below related link
https://collaborate.pega.com/question/which-cache-directories-can-be-cleaned
Shanthini Charles
