ES
Last activity: 10 Oct 2018 11:01 EDT
How display data from two classes
I want to display data from two data classes in repeating layout in single section in work class. How to implement this?
Likes (1)
Nicholas Edwards -
Hi Satya,
Are you looking to display the two data classes information in the single repeating layout in the section of work class or in separate repeating layouts in the section?
If it is a first case then i don't think its possible to provide 2 different sources to your repeating layout.
Regards
Mahesh
ES
Hi Satya,
I am not sure about your exact requirement but if you can use repeating grid layout then you can source it with report definition and in this report definition you can use class join to get the data from two different class.
Please let me know if this is what you are looking for.
Vikash
ES
Hi Sathya,
Could you please add the screen-shots of the configuration of the section that you are using to display the data.
If you are using a repeating grid have you added the columns in the grid?
Vikash
People Tech Group
Can anyone tell me if we click on More, Details should be display the all 10 recent transactions details.
sonia.
Arunreddy Shyamala Martin Wolters Abhishek Sharma SriHarsha Anika Rishabh Shukla and 7 More
