HCL Technologies Ltd
Posted: August 3, 2017
Last activity: August 3, 2017
Last activity: 3 Aug 2017 4:58 EDT
How to compare two blobs data?
I am not sure is there any method to compare two blobs data, but we have alternate options like extract the both blobs using the BIX extract and compare or use any third party db tools.
Yes, BIX will extract the BLOB in to separate columns and then you will be able to perform different comparison operations.
If you are able to use Connect-SQL for the mentioned tables, then based on the database that you have, you will be able to use the sql queries and be able to compare.
