COGNIZANT TECHNOLOGY SOLUTIONS
How to read data from excel sheet if it has two tabs?
Hello Team,
I have an requirement to read data from excel sheet which has two tabs. Each tab has multiple columns. I have to use file listener to read the data.
Is there any OOTB features? The below URL doesn't help much :-
https://pdn.pega.com/community/pega-product-support/question/how-read-data-multiple-tabs-excel-sheet
Appreciate your quick response!
Likes (1)
Raghavender Reddy Lankapothu -
It is worth going through:
https://mesh.pega.com/docs/DOC-89988
https://mesh.pega.com/docs/DOC-89449
https://mesh.pega.com/docs/DOC-89784
Well, thank you for sharing the details but unfortunately I m not looking for to extract the data in to excel sheet.
I have an excel sheet which I multiple tabs & I need to read data and load it in DB. How do I do this? File listener rule does this but only for single tab , doesn't work with multiple tabs. Please help!
You can aswell look into https://collaborate.pega.com/question/how-read-data-multiple-tabs-excel-sheet
Looks like the similar one
No The activity is not helpful :(
Hey Marissa, I have already updated in the post, the activity which you have shared is not helpful so please share more details. Thank you!
Pegasystems
See if the pxUploadCSVResults flow action and associated activity are useful.
Need to try this, but if you have all ready implemented so can you please share more details? Can I add this flow action in my current flow and it would upload all data ( even data in multiple tabs?)
What's the best way to implement this? Thank you!
Please let me know what's the best way to implement this functionality.
Truviq Systems Private Limited
Hi Varun,
Find the attached document which contains detailed steps to achieve the desired.
Hope this helps !!
Pega Version used: 7.1.9
Srikanth Y.
Gopinath M
Hi Srikanth,
This is one of the best help ever provided to me. Much appreciated!!
However, the sample excel sheet attached in the document is not accessible. Could you please share it again. Or upload the document separately? I'm using Pega 7.2.2 and going to try this approach and will update you my further response
Hi Varun,
Thanks.
Attached the sample excel sheet used in the illustration.
In the sample sheet, I only used two columns. You can add your required columns in the same format as in the sheet.
Srikanth Y.
Tech Mahindra
Hi Srikanth,
Can I use the same procedure to read the data from .CSV file and load it data tables.
Thanks in advance,
Satya.
Hi VenkataSatyanaraB,
The above method is not working for csv type files.
As mentioned above in one of the comments, you could use pxUploadCSVResults for csv type files.
Hope this helps !
Srikanth Y.
Tech Mahindra
Hi Srikanth,
I tried by calling pxUploadCSVResults in post-processing activity by passing the values for required parameters. I am getting thesome exception.
I am attaching the screen shots of what i did.
Please help me in resolving the problem. If possible you can share your number.
Satya.
Naresh Udutha
Hi Satya,
Attached the file with the detailed steps.
Hope this helps !
Srikanth Y.
Tech Mahindra
Hi Srikanth,
Thanks a lot for detailed reply.
I did the same as per the attached document. But Still I am getting the error on pyWorkPage of Clipboard.
.pyFileName: Invalid property reference123
Please find the attached file for details. Please share your number.
Satya.
