How to insert data into an excel sheet from database
I want to know how to insert data into an excel sheet from DB2 database..
Regards
Srilipta Nanda
Regards
Srilipta Nanda
Probably high-level you might want to do this:
1. Map your DB2 Table into PRPC as an 'External Table'.
2. Create a PRPC 'Report' based on that data.
3. Use the 'Export To Excel' facility (which is built into the Report Viewer) to generate your Excel file.
