Provide Pega Portal without login
We have build a portal in Pega which is available to all users in the organisation. In order to avoid logging in each time the portal is used, we have added a 'quest' account in Pega and provided an url to all users that contains the credentials to login. For instance:
Now this works perfectly. However our security department does not like these credentials within the url. So is there another way to provide a portal to users where they do not need to login, and that does not have credentials in an url?
Thanks, Marc
Hi Marc,
Thanks for posting on PSC.
As you want the portal to be unauthenticated and application should be made available to all the user within your internal network.
I would agree with the previous suggestion of implementing SSO as it will address security problem as well.
Refer below links for implementation details:-
- https://docs-previous.pega.com/web-single-sign-sso-saml-20 (Please refer links in the left side panel as well)
- https://collaborate.pega.com/question/how-implement-single-sign-prpc-722-pega-personal-edition
- https://pdn.pega.com/community/pega-product-support/question/sso-implementation-pega7
- https://docs-previous.pega.com/single-sign
I am not sure, how much IAC would be beneficial in your use-case.
Though I would try to research more, your initial issue of skipping authentication or passing alternatively username/password.
Hope it helps you in your implementation. Kindly notify if it does by marking this post as answered/helpful.
Asif
