How to create PEGA Portal without login
Can anyone help me, how to create PEGA Portal/Website without Login pocess ?
Hi
Are you referring Single Sign On (SSO) feature?
What is SSO feature ? And how to use it ?
Hi Yudhi,
Can you confirm the PRPC version your on?
When using SSO like Siteminder to authenticate users logging into our PRPC application. The URL being sent from Siteminder to PRPC will only contain the Username, not a Password.
Is this what you mean when you say you do not want login process to the portal?
Shanthini Charles
Pega version is 7.1.9.
My requirement is build the simple website which all people can access it without login.
Thank you.
Hi Yudhi,
Sorry for the late response but I doubt we can achieve this as it is mandatory to login.
Shanthini Charles
Hi Yudhi,
You can customize your login page using the below article and you can have what ever data/images/links you want to keep in the log in page.
https://docs-previous.pega.com/customizing-pega-7-login-screen
So that user can see the basic information with out login itself.
And from my understanding you want to create a static page. For that I don't think you need Pega. You can not use Pega for your requirement as pega completly dependent on Operator and access groups .
Regards
Saran
