change class attribute
A tabbed harness is loading and the out of the class of the <div > is yui-content contents tabContent .The display style is none. I want to change that to 'table' .
how to do that.Can we change using javascript.Or else what would be other best way.
Hi Debasishg,
Thanks for posting on PSC.
Can you check the visibility condition of your harness, is it marked hidden? Make sure value for visibility is always.
To change any format, you can add format in skin(define display as table) and provide the same format under presentation tab.
If this doesn't answer your query, please explain your complete usecase. so, we can provide more input.
Cheers,
Gurpreet
