Activity Still Requiring Interaction after attribute changed to False
I'm testing the use of activities without having an interaction active/started. In my test project, I am using the provided activity (AddPlan) text found in the default XML. I've changed the RequiresInteraction value to False, but I am still receiving the error message show.
Note: I have tried this with other XMLs and still receive the error. For testing purposes, I'm using the XML data found in the comment section of the default XML.
Visual Studio Professional 2015 with Pega plugin .1030
After opening a support ticket, it appears the support team has confirmed my original resolution.
"I've talked to one of our developers to confirm that you do need to start an interaction in order to start an activity. The property that you set to false allows you to start the activity with out an active interaction."
