Common Wealth Bank of Australia
Last activity: 30 Jan 2018 10:45 EST
Elastic search indexing in a multi-node setup
It will be great if you could clarify the below queries
1. In a multi-node setup, do we have to configure SearchSOAPURI (DSS) even for Elastic search?
1a.)If no, how does search works in the node which is not added as indexing host node in search landing page?
1b.) If yes, what will the value of the following DSS indexing/hostid,indexing/hostname,SearchSoapURI & indexing/explicitindexdir if two nodes are added as indexing host nodes in the search landing page
2. What is the significance of node to node communication via tcp 9300-9400 in Elastic search? Does it helps in building the index files or retrieving data while performing a search in Pega ?
***Updated by moderator: Lochan to branch reply and create new post***
