accenture
Last activity: 24 Jan 2018 2:53 EST
No matching Product or Application found with inputs Product
We using prpcServiceUtils.properties file to export and import.. Facing issue while using export. Set all the required details for export on prpcServiceUtils.properties file and tried running from command line, getting below error.
[java] Error Messages : No matching Product or Application found with
inputs Product Name:pyStrategyBackport Product Version:01-01-01 Application Name
: Application Version:
I am using Pega 7.3.1 version..Tried exporting both pega OOTB product and custom product.. both failed!!
Note: Same set up works for 7.2.2 and I am able to export using prpcServiceUtils
Attached detail logs and properties file details..
Do you have a product rule with this name and version? Does this PegaUsername operator have the correct access group to see it?
[pega:propertyparser] pega.rest.username=PegaUsername
accenture
Yes I do have Product name and version on same instance, and the user has correct access group.. tried even with the custom products but still same issue..
Could you please share the screenshot of your product rule from designer studio which contains the product version.
accenture
one of the custom product...
product Name:ARR_RuleProduct_25Sept2017
product Version:01-01-01.. Still same issue.. attached SS..
Could you look into this document which has some troubleshooting tips for this kind of issues and let me know if it helps you or not.
accenture
I am using Pega 7.3.1 prprcServiceUtils files..
pega.rest.server.url=http://localhost:8722/prweb/PRRestService/
pega.rest.username=admin@cssa
pega.rest.password=rules
export.archiveName=ExportCSSA.zip (Dhulappa- If I use .zip it fails again)
export.productName=CSSAProduct
export.productVersion=20170831.123512
Also there is no record in f Log-PegaRemoteManagement-Export class as export process fails before starts..
export.archiveName=ExportCSSA.zip (Dhulappa- If I use .zip it fails again) -> could you cross check the error in the PegaRULES log file instead of the prpcserviceutils task log during the export process with and without this change. Share the log file if you could notice any useful information related to this failure for further analysis.
accenture
I checked with both the approaches, there are no pega logs related to export..
accenture
Also tried importing using prpcServiceUtilsfile (Export process was done manually) got the below error..
2018-01-23 05:01:52,888 [.PegaWorkManager : 6] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.archive.PRJarFile) ERROR - Unable to create PRJarFile java.util.zip.ZipException: zip file is empty at java.util.zip.ZipFile.open(Native Method) ~[?:1.7.0] at java.util.zip.ZipFile.<init>(ZipFile.java:231) ~[?:1.7.0] at java.util.zip.ZipFile.<init>(ZipFile.java:161) ~[?:1.7.0] at java.util.jar.JarFile.<init>(JarFile.java:169) ~[?:1.7.0] at java.util.jar.JarFile.<init>(JarFile.java:133) ~[?:1.7.0]
The above error seems to be due to this issue, have a look into the PDN article and follow the suggestion.
Have you actually tried with a product Name of ARR_RuleProduct_25Sept2017 and version 01-01-01? Try this with a product rule that you can successfully generate a RAP from within designer studio so that we know that the issue is not related to the RAP content.
accenture
I am able to create RAP for ARR_RuleProduct_25Sept2017 and version 01-01-01 from designer studio.. It generates zip file on service export directory..
Ok, so when you run prpcServiceUtils for the same ARR_RuleProduct_25Sept2017 and version 01-01-01 what do you see in the logs? Is the pega.rest.username=admin@cssa operator that you are running prpcServiceUtils with the same operator that can successfully run the export from designer studios?
accenture
there are no entries in the log about export process.. I tries logged in with the same user pega.rest.username=username while performing export from designer studio...
