Pega robotic runtime not working.
Double clicked on runtime and nothing happening. It's new machine. No error trace no event log and no log file. Really appreciate if any one can suggest debug steps.
***Updated by moderator: Lochan to add SR details***
This issue was caused by lack of pre-requisites being installed. This was resolved by preforming a manual install which force installed all Pega Robotics pre-requisites.
First check Task Manager after starting OpenSpan.Runtime.exe. Do you see the process there? Do you see the icon in the Task Tray.
If no, then check the microsoft event viewer, check for a crash or some other issue.
Let me know.
OpenSpan.Runtime.exe shows up for a fraction of second in Task Manager and disappear. No entry nothing in event viewer. Could you suggest any other steps for debug.
hi ,
did u find any solution for this, facing the same issue.
Nope. I have raised a service request and support member is looking at it. As of now no solution.
Hi Sameer,
Please let us know the SR number so that we can tag that to this post and track it. We will update this post with the resolution once its available.
Thank you!
I have updated the original post above with this information and see that the is currently under investigation.
No one has a clue now.. I did provide the trace log and nothing for now.
Hi Chris,
Could you please elaborate as to what steps need to be performed so that this issue can be resolved.
Abhishek
