Atos Syntel
Last activity: 11 Sep 2017 12:20 EDT
Decision shape is not routing to end shape
I have a decision table configured on a decision shape, based on the results of the decision table the case will be routed to a respective assignment, If the decision table returns the otherwise value the case should be routed to the end shape.
Test cases for routing the case to different assignments based on the result of the decision table worked except for the end shape, routing to the end shape does not work even when is switched the connector configurations between the assignment and end shape.
So I am not able to route the end shape, when i try to do so it just routes to one of those assignments connected to the decision shape, is this normal.
