html table schema rule doesn't work pega
Unable to interrogate html table using html data table schema match rule or Table Head match rule
If you're able to interrogate the control you can use Select Element to see how far up the tree you can interrogate. If you can access the table as a regular control you'll be able to interact with it from there.
