Standard Chartered Bank India Branch
Open Span Object Explorer (Shared)
Can you please let us know if the Object Explorer can be utilised in a Shared /common way.
We have an application with the same source code across 40 countries , We tried with Openspan and interrogated the objects for one country , however
that same object explorer could not been used by the other country (with the same source code only the URL different) , can you please let us know if there is a solution in place.
Capturing the Object repository for all the countries with the same source code will be a Duplication and tedious task.
Kindly let us know if there is a work around for this constraint
