capgemini
capgemini
capgemini
Posted: Jul 18, 2017
Last activity: Jul 19, 2017
Last activity: 19 Jul 2017 8:51 EDT
Can anyone say what is the major difference between sub reports and class joins in Report-defination and also where to use these exactly.
Raghuvamshi
***Edited by Moderator: Marissa to update categories***
class joins to enable reporting on data from multiple classes or tables. For each class join, define one or more logical conditions that specify how to match or join corresponding instances in different classes.
Sub-reports enable results from any report definition (including a report definition defined on a different Applies To class) to be referenced and included in a different report definition.
You can find the entire description in detail in the Pega help.
To access the same, open an Report definition > Click on Actions > Get help > Open the data access tab. \Hope that helps.
Faizan.
Hi Raghuvamshi,
Sub-reports within Report Definition reports to simplify assembling data from several classes, or to satisfy complex conditions. Like creating sub report and placing different class joins with logical conditions with in that report.
https://docs-previous.pega.com/when-and-how-use-sub-reports-report-definition-reports.
This link will helpful for clearly know about sub reports, where and how to create it.
Class joins are used, when we need to call properties/data (optimised) from another class to this class( where RD created) and placing logical conditions as per the requirement in RD.
I hope this will helpful to you.
Pawan B
