What exactly is tested by hitting on 'Test Connectivity' button inside the Connect SOAP and Connect REST services in PRPC 7.1.9
Does the Test Connectivity button present for Connect SOAP and Connect REST is testing that the service endpoint URL is up and running? What does a Fail and Good status means?
Within Pega, you can continue to use "Test Connectivity" feature on SOAP/REST/EMAIL/FTP/FILE/JMS services rules to check if external service is up and running. Why do you need an another Pega utility?
