Infosys
Last activity: 17 Feb 2017 6:57 EST
test connectivity for Connect-SOAP without running application in production
We have a SOAP integration(Connect-SOAP) with external system for our application. How can we test connectivity in production without running the application? we have dummy data in production for validation but won't be able to launch the portal. Is there a way to run Connect-SOAP rule and pass input xml? Environment is PRPC 7.1.8.
Hello Arundhati,
If i understood it correctly your service present in a production system and also dummy data available there .
You don’t want to invoke the production service through pega due to some reason .
In that case you can create the same service in one of your lower environment and first test the service through SOAP UI or any other tool .
If the service is working fine now test the connect soap rule .
Then at last scenario you can follow the same changes in production .
Let us know if you’re looking for something else .
Arun
