DocuSign : Signed documents not received back
I integrated docusign as per https://pdn.pega.com/integrating-docusign-pega-7-platform/integrating-docusign-pega-7-platform. Even though the Event Notifications are configured for "Completed", I didn't see documents returned back.
I read on PDN that pyURL on pyEventNotification has to be a publicly accessible URL. But at my employer it's intranet and URL is not publicly accessible. How to get these documents back as case attachments.?
Which version you are on? If you are on 7.2 , have you applied HFIX-26109 ?
What is this HFix for?
GovCIO
Hi Santanu,
As we are going to use V7.2.2 for Docusign integration project, I don't think we fall into this issue. Please confirm.
Ravi Kumar Pisupati.
Hi Nikhil,
Did you check the unsigned document? does those get processed and attached to the work object? Any errors in the logs?
Mukul
I mean, does the normal file attachment works for you?
Mukul
Hi Mukul,
Yes it works.
Accenture Inc
PH
Any other work-around for this same problem?
Hello!
This post looks to be old and I see that you've created a new post: DocuSign - signed documents not automatically attached/sent back to the case
Great practice!
