synechron inc
How to reduce the height of the grid repeating layout and the background color when we click the collapsible repeating layout.
Hello all,
I have two requirements which I am facing the issues with repeating layout.
1.I have repeating layout with 2 sections in the columns the rest are text inputs my question is while I am adjusting the height by clicking the row properties and changing the height it is not adjusting , it was showing the same height that was before changing. How can I adjust the height when we have sections in repeat layout?( I tried using the tree grid container but didn't find any solution for that)
2.My repeating layout is a collapsible one where we have different logic in it, how can I change the background color(of repeating layout) to blue as soon as a I click the repeating layout ?
Please help me out from this would be much appreciated
TIA.
2.
HI
From what I understand you are including a section in a column of a repeat grid and your are not able to adjust the height of the cell . Is that right ?
If that is the case, can you try using fixed size and check if that helps ?
Regarding your second question
can you clarify when / what do you want highlighted ?
1. Do you want to click on a row in repeat grid and want that row to be highlighted ? This is available by default when you use "Default" style presentation ?
2. DO you want the entire repeat grid to be highlighted when you click on it. May be some screen shots could help.
