Infosys Ltd
Last activity: 6 Jun 2017 15:40 EDT
Where we can call Validate Rule for Modal Window(Pop Up) Property Validations?
I am unable to full fill the validations on Local Actions While I am submitting the Button It can't allow to Submit as I am not using defualt buttons here I am using Customized Button On top of that I am configure Validation activity(Obj-Validate). Kindly Suggest Work Around On this...
Upon reviewing the associated SR, I see that a Local Change has been issued as a resolution. If you have the same question, please see SA-38065 Validation rule does not prevent modal window submission for more information.
Hi Venkat,
Thanks for writing to PSC.
As we have option to customize the OOTB buttons,you can customize that to your need and still use all the options available in Actions tab.
Can you please provide your business requirement details that led to the use of custom button.
Based on your input, I will be able to suggest further.
Gurpreet Kaur
Wellcare Health Plans Inc
I have the similar challenge. I need to run some validations in a modal window.. Am trying to run through the flow action validation rule. flow action validation rule is working fine when I add just one property. But the strange is that, validation rule cannot prevent from submitting the flow action though there are messages on the other properties. is there any known issue in 7.1.7??
Thanks in anticipation..
Paturi
Hi Paturi,
We haven't come across such issue. I will be able to help you further on this, if you can send me the configurations details of properties and flow action validation.
Gurpreet Kaur
Gurpreet Kaur
I have an SR logged with Pega. Product Support is working on finding the root cause. Thanks a lot for your responses.
Thanks for replying! Could you let us know the SR number so we can connect this PSC thread with the SR?
Accenture Australia
In pega basically we have two of types of validations,where we can give at the server side and client side.Both can restrict the flow action to move forward in the modal dialouge .Please add some more comments about your requirement.Then we will able to add some on your requirements.
Thank you.
