AIG
Last activity: 30 Jun 2017 11:06 EDT
using IBM zEnterprise Data Compression on PEGA apps running under java-7
We are trying to use zEDC tool for data compression so we are looking for some inputs on where compression takes place within the PEGA framework… some possibilities were thought to be during rules refresh, or after deleting the pega_rules marker? It seems from the logs that inflate is used a lot, which also supported in the zEDC compression accelerator (not just deflate).
any further inputs is appreciated.
