Issue with Data Propagation in implementation layer after using New Application wizard
An application is created using new application wizard. When proceeding a case in the implementation layer an error is thrown when a new child case is added and the issue is as below :
This error is related to data propagation from Parent case to child case.But when we re-save the pyDefault case type rule in the implementation layer and create a new case the issue doesn't appear. Is there an issue with the application wizard when it saves the case type rule into the new application.
***Updated by moderator: Lochan to add SR details; add enhancement ID***
